Unlock Bootloader
SOLVED
Nations112
Visitor
Unlock Bootloader
Hello
Plan to unlock the bootloader version 1257-6719
Is the ability to unlock the bootloader differently?
It Will Be Possible to install vanilla android maybe locked bootloader?
http://www.gsmarena.com/sony_xperia_s_will_get_vanilla_android_as_a_google_experiment_-news-4669.php
I'd like this android then installed.
1 ACCEPTED SOLUTION
Accepted Solutions
Thommo
Genius
You need to check if your Bootloader is unlockable by dialing *#*#7378423#*#* then choosing Service info then Configuration then at the bottom it will say Bootloader unlock allowed either Yes or No
If it says Yes then follow this link http://unlockbootloader.sonymobile.com/unlocking-boot-loader and start reading
If it says No then there are ways to root etc so wander over to XDA to read up on how
5 REPLIES 5
aravindad
Visitor
Its very simple to unlock..
check it : unlockbootloader.sonymobile.com
Thommo
Genius
Nations112
Visitor
I have NO
Is there any way to change to Yes?
Installing vannila android will fold a locked bootloader
Thommo
Genius
I've not seen Vanilla released yet - It may get made into an ftf file which you will be able to use using flashtool - If it's an ISO or image file as some prefer to call it then it may be possible to root and install via CWM recovery however please do not quote me on that
Nations112
Visitor
But I will not be able to install Kernel?
thank you for your answers. -)
