update problems
SOLVED
c385
Visitor
update problems
Hi, everybody.
I cannot update my phone,or do anything (like transfering, repair) with PC Companion!
Always shows like, "try again later, the application is not installed"
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
13 REPLIES 13
Uliwooly
c385
Visitor
thx. i tried these, but nothing happend what solved my problem....:/
Uliwooly
do you still get an error? if so, restart your PC > disable your firewall and antivirus > run again
which OS do you have?
c385
Visitor
i use win7, i tried everything: restart my PC, remove phone-and connect again... always error....
(i cant even repair my phone, or anything)
Uliwooly
post a screenshot of the error
c385
Visitor
i dont think you will ióunderstand it becouse its Hungarian, but i try 2 translate well.
c385
Visitor
The application havent been installed well. Try again later.
There is another mess.: Cannot conect to the Server.
Uliwooly
what about Sony Update Service (SUS)?
c385
Visitor
the same...
