Update to JB not working
OPGELOST
Mark0l_
Bezoeker
When I run PC Companion or Update Service, I fail every time. When I'm meant to hold down the down button a plug in xperia, it doesn't do anything.
It does only 2 things:
1) if I hold DOWN button, the led turns light green (ye, actually a bit lighter then when charging) and after few seconds, it changes into red and show battery image and continue charging....
2) if I hold UP button, the led turns violet. On pc, there is  some pop-up with selecting looking for a driver, and two options to cancel looking for drivers. If I click on "search for drivers" (or sth like this, because my language is CZ), it starts to search but after few secs mobile goes to charging state and pc says the device was unplugged..
I had trouble installing ICS too, but this http://communities-origin.sonyericsson.com/thread/47945?start=0&tstart=0 worked for me. Updating from webpage worked for me. But obviously, this is not possible anymore.
Thanks for any advices!
15 ANTWOORDEN 15
Uliwooly
try this
turn on your wifi > settings > about phone > software update
Mark0l_
Bezoeker
Thank a lot for your trying, but nothing helped.
Than today I tried it once more with different cable and different pc just for fun. And voila.! So Im running JB. Nice piece of software but..
Why update center in phone never says there's an update? And for god sake, why missed sms/calls doesn't appear in lockscreen? That made me very sad
Uliwooly
if you have a pattern, pin, password lock you are not going to see the notification, now if you want to get notifications like the iPhone there are myriad apps that will do that.
Don't forget to mark the Correct Answers & Helpful Answers
Mark0l_
Bezoeker
I just have to swipe screen to unlock.. Also I saw there is meant to be a feature to adjust intensity of vibrations, but I can't find it. Maybe Telefonica O2 did sth 😕
Wow, you also gave me links, you are awesome, thanks!
Uliwooly
I know I am (awesome)
