update X8 in Android 2.3 ver
SOLVED
Not applicable
pl's upate the X8 in Android 2.3.3 Version.
pl's ..........................
1 ACCEPTED SOLUTION
Accepted Solutions
Martha-
Contributor
We will not be updating past 2.1.
If you take a look at the "More Like This" option on the right side, you may see some alternatives.
2 REPLIES 2
Martha-
Contributor
you could install a Custom ROM 2.2, 2.3
http://forum.xda-developers.com/showthread.php?t=914513
