I want to know how to disable the USB charging when i connect my XPERIA S to PC ?
I'm afraid there's no such settings available as standard in the Sony Xperia S.
In that case you have to get hold of some kind of third part app that might be able to enhance that function. Check Play Store to find one.
What do you think about this forum? Let us know by doing this short survey.
I don't see how this is possible
The USB power output is 5V
The power output from your supplied plug is 5V (Atleast it is in the UK)
So if you are pluging something into a live power output be it USB or powerpoint the power has to go somewhere and that power is used to charge your phone it is also used to transfer information between Pc and phone hence how you Pc knows that your phone has been connected
