Xperia Arc LT 15i videocam didn't record the audio. Voice memo recorder work normaly : any advice ? Thanks
Solved! Go to Solution.
Check if the mic might be disabled. Open camera and press menu key to get settings. Check that mic is enabled.
Excellent, the microphone was disabled, now everything works perfectly.
Thanks & Best Regards
