xperia s ICS battery draining problem
zakirox
Hi every one, My XS battery is draining too fast i dnt know why is that here i have been attached som images please help me Slightly_frowning_Face
Screenshot_2013-07-21-05-54-26.pngScreenshot_2013-07-21-05-54-49.pngScreenshot_2013-07-21-21-35-40.png
Screenshot_2013-07-21-21-35-21.pngScreenshot_2013-07-21-21-35-27.pngScreenshot_2013-07-21-21-36-04.pngScreenshot_2013-07-21-21-36-23.pngScreenshot_2013-07-21-21-36-27.png
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Uliwooly
uninstall all this apps
taskillers
task managers
battery apps
antivirus
ram apps
booster apps
you do not need those apps at all
15 ODPOW. 15
Uliwooly
I can't see how long your top 4 apps were on, but its seems that you have really bad network coverage and thus drains your battery quite fast.  it will be helpful to include screenshots of the top 4 items
zakirox
Screenshot_2013-07-21-22-19-24.pngScreenshot_2013-07-21-22-19-52.pngScreenshot_2013-07-21-22-20-02.pngScreenshot_2013-07-21-22-20-09.png
please help me and i am using AVG Slightly_smiling_Face
Uliwooly
taskillers
task managers
battery apps
antivirus
ram apps
booster apps
Uliwooly
you can repair your phone with SUS or PCC but I think the issue is the poor network coverage
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
zakirox
thanks i will try this now by uninstalling antivirus app Slightly_smiling_Face thanks a lot agin for your help.
zakirox
now i am on ICS, will it goes to JB if i repair with sus? Thinking_Face because JB still having a bug with 1080p video recording i love my XS camera Winking_Face
Uliwooly
indeed if you use SUS or PCC or Bridge it will update to the latest firmware available, you can do a settings reset on your phone, make sure to backup all your contacts and anything that you don't want to lose
Uliwooly
go to settings > about phone > status > signal strength
how many -__dBm do you have?
zakirox
yesterday i did full factory reset. then again i sync my gmail and facebook after that installed all the apps wich i had already then the problem raised again but, i didn't chek my battery status after factory reset without installing any apps this is the mistake where i could have been done :smileysad:. will the device cause any damage if i do a factory reset again or else is there any possible way to get back to normel without doing a factory reset?
