Xperia T cannot boot after OS update
SOLVED
wawrzek1
Visitor
I have purchased Xperia T recently (in UK for O2 network) and tried to update software yesterday and something went wrong. I cannot boot.
- It goes in loops - Xperia and Sony logo -> "abstract" boot start moving image (I think it appears 3 times) -> black screen and again.
- I enforced stop/restart with power button and "volume +" and tried to booted it again - no success.
- I tried to connect to Sony PC companion - it cannot see the phone.
Phone is fully charge. Please advice.
I might be the same/similar problem to http://talk.sonymobile.com/thread/143758?tstart=0
1 ACCEPTED SOLUTION
Accepted Solutions
wobba-lee
Visitor
Exactly the same issue as in the link. Follow the instructions in their. PCC will not see your device as you can not turn it on but SUS works from the device being off as you select which device you have unlike PCC which detects it.
3 REPLIES 3
wobba-lee
Visitor
wawrzek1
Visitor
Thanks. I wrongly assumed that SUS is a part of PCC. I'll downloaded SUS and  kicked off it.  It said phone has the latest replease already, but give me a changes to reinstall it anyway what I'm doing it now.
wawrzek1
Visitor
Phone is working again after updating with SUS. Seems that I've not lost a lot of - some settings.
