Xperia T Internal Speaker distortion
SOLVED
Bertjuhh1
Visitor
Hi all,
Since a few days, my Xperia T internal speaker (the sound from phonecalls) has some sort of distortion in it.
Like it has a crack or dust in it.
I did diagnostics and the speaker works, but still with the distortion in it.
Is there a way to get to this part so I can clean it?
Or should this be fixed by a company?
I bought the phone without a contract and it is not even 1 year old, think i still have warranty?
Regards,
Robbert
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
http://www.sonymobile.com/global-en/support/contact-us/
Contact one of your closest sony services,check for warranty.If still active,take them the phone.It may be more than cleaning needed.
alexdon
2 REPLIES 2
_alexdon_
alexdon
Braddington
Visitor
If it is sounds like static then I have also experienced this problem along with many Xperia T and TL owners. So far no one knows what causes it but it is a hardware flaw with the Xperia Ts and TLs. My first Xperia TL had it and my second one didn't have it at the beginning but later on it developed it. It comes and goes though. The Xperia T/TL supports HD voice so this static sound just ruins the experience.
