BBC iPlayer & internet browser not working on KDL 32HX753
profile.country.en_GB.title
alrober84
Hi,
I noticed las night that the the iPlayer on my KDL 32HX753 no longer works. I used the iPlayer facility on my PS3 instead (similar looking interface, worked fine). I have also tried to connect using the wed browser, which is also not working (never used it before so not known).
I have carried out all these tests.
1. Checked all connections.
2. Checked that the TV said it was connected to the internet Home | Network Setup | Check connection
3. Rebooted my internet router
4. Checked that rd1.sony.net/tv1 & help.opera.com could be seen by a PC on the same network
5. Tried the LoveFilm interface, Sky News worked.
6. BBC News was also not working
What is broken?
Alistair.
Tagi (4)
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Anonymous
Nie dotyczy
Hi there
Just tested my iPlayer on my NX723 all works fine. Not knowing your location - http://www.a516digital.com/2013/03/late-snow-takes-its-toll-on-tv-and.html
My only other bit of advice is to check to see that your on the latest firmware, and maybe clear the settings by a factory reset. Interesting that iPlayer worked on your PS3 but not on your TV.
Cheers
2 ODPOW. 2
Anonymous
Nie dotyczy
Hi there
Cheers
alrober84
Thanks for the suggestion. I'm using ethernet for the iPlayer so snow shouldn't of been a problem. The router still found the internet on the PC. It might be my ISP (Talktalk), which I'm going to leave a note in their forum.
I've checked the firmware, even tried to load it again - but it said lastest already loaded. :
I was trying to avoid a reset, but, I'll try it a bit later!
Cheers.
It is now later, and after a factory reset (not as painful as I thought!) all is well!
Message was edited by: alrober84
