BRAVIA 46HX 903
SOLVED
profile.country.en_GB.title
tony20172
New
BRAVIA 46HX 903
ON THIS MODEL CAN i USE SKYPE AND HOW ???I also use a home cinema  bluraydiscdvdplayerBDP-S470 any help would be appreciated  tony
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
Member
as far as i can make out, the only player in the Sony stable capable of skype is the flagship BDP-S780 model.
4 REPLIES 4
Bravia55HX
Member
Hi,
well according to the specs for this well specified model, skype is not available im afraid, also can you be more specific with your question regarding your BDP-S470 please, what is it you wish to know.
tony20172
New
well on the computer it states that you can use certain dvd players for attaching skype that my train of thought tony
Bravia55HX
Member
tony20172
New
Yes I think that you are right I will just carry on useing my computer for skype /Thanks anyway  tony
