Connecting my Sony - KDL-40EX503 to a freeview recorder
SOLVED
profile.country.en_GB.title
covbaldy
Visitor
Hi,
I'd like to be able to use my freeveiw recorder, its just a cheaper Toshiba 2nd hand freeviw box, how do I hook it up and more importantly how do I programe the TV to use the freeview box and not the TV?
Cheers
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
Member
Hi,
plug in the box to the mains, connect the aerial lead from the wall to the box, connect the box using the appropiate cable, for example scart lead or if a later device HDMI to the tv then all you need to do is select the input on the tv to the soarce and thats it! (hopefully)
2 REPLIES 2
Bravia55HX
Member
Hi,
covbaldy
Visitor
Awesome, I thought it might be that simple (well I was hoping it would be!)
Cheers for your help.
