My Bravia is registered, I'm connected to the internet, but when I try to get into You Tube I need to put in id etc., but I don't recall setting up an id and/or a pin - how do i move to vieiwng the you tube content? Thanks to anyone who can help.
SOLVED
profile.country.en_GB.title
Killerpees
Visitor
thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
Member
Hi,
just use the same id and pin you used when you set up your you tube account on your pc.
2 REPLIES 2
Bravia55HX
Member
Hi,
gofrost
Member
if you hav'nt create a google account and login with that this does work
