New TV connection problems to digibox
profile.country.en_GB.title
suejbendall
I cannot connect a new LCD Digital Colour TV EX32/26 to a digibox.
I just get a 'No Signal' message on the screen.
This is essential as the box has a hard drive which can record programmes.
(We do not go digital in ths area until March 2012)
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Anonymous
Nie dotyczy
Hi there
As you have connected the digibox - simply turn it on first.  Then using the TV's remote control, select the AV1 Input via the Input Select button.  See pictures below:
TV's Remote Control:
The following menu may appear - Scroll down and choose AV1:
The settings for AV1 are more designed to name it something memorable (ie Digibox) - However I have only experimented with HDMI on this.
If this doesnt work, ensure that the SCART cable is connected fully (and any other cables) - as in, not slightly out.
I cant think of anything else at this stage, as basically there should not be much to it, plug-and-play as such.
Hopefully that helps you.
Cheers
6 ODPOW. 6
Blencogo
Hi suejbendall.
This will not be possible using a RF cable (like an ariel cable) as the TV cannot accept an Analogue RF Signal.
What model is the digibox?  What connections does the digibox have?  Does it have SCART? S-Video? Composite Video?  Most digiboxes have a suitable connection.
:thinking:
suejbendall
Hi Blencogo
This is, I'm afraid, all Greek to me but.....
It is a Logik LPVR88
At the back it has connections labelled
CVBS
RS232
Aux Scart
TV Scart - by which the Logik scart cable is attached to the TV
Antenna 1 in & out
Antenna 2 in & out
Hope this means something to you!
SJB
SteveXHis
Hi,
I have the same problem.   I just purchased a KDL40 TV and trying to connect it upto the digibox. We want to continue using the digibox as it has a recording facility.
The digibox has just just a scart connection which I connected upto AV1 scart on the TV  but the screen is
blank.
When going through the settings for AV1 I am confused which type it needs to be  - options are basically
SAT, VCR, GAME, PC, CAMERA, DVD, HOME , edit.  I've tried most of these but nothing.
The digibox is fine with the old LG LCD TV which I've gone back to using.
Can anyone help?
thanks,
Steve
Anonymous
Nie dotyczy
Hi there
Whats the exact model of the TV?
Cheers
SteveXHis
Hi,
Its a   KDL40r473abu   which purchased from John Lewis yesterday.
thanks,
Steve
Anonymous
Nie dotyczy
Hi there
Cheers
