Skype and other widgets on 2011 devices
SOLVED
profile.country.sv_SE.title
phazer_se
Visitor
Hi!
I just bought an KDL-55EX723 and i'm missing skype, widgets and other things that should be available trough a firmware upgrade.
But I cannot find any upgrades and the tv upgrade option says it's up to date.
Am i missing something or is the new firmware not relesed yet?
Regards,
Tommy Herman
Message was edited by: Catmambo
Tags (3)
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
Catmambo
Contributor
Indeed, they are being pushed out via firmware update very shortly as far as I understand, hopefully in the next couple of weeks.
Will sticky this for now as i'm sure it will be asked again.
Thanks
2 REPLIES 2
Catmambo
Contributor
Thanks
phazer_se
Visitor
Thank you! :slight_smile:
