- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
SONY BRAVIA TV KDL-22BX200 Loss of Picture Sound still works
I am contacting SONY support for advice on how to repair my BRAVIA KDL-22BX200 24" TV - which has no picture but the sound is working.
The TV was purchased from ARGOS store in Haverfordwest and the product serial number is: 00401498.
I have had very good service from this TV and it about 18 months in use.
Your help is requested- a quick reply is appreciated.
Thankyou.
Yours faithfully,
Fiona Madan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
No picture but sound is ok - Is that on Freeview or another connected device?
By the way, this is a Community Forum, and not Sony directly themselves.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This is using Freeview only. Have not tried using the screen as a monitor connected to a PC.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The TV is a 22" unit and not 24" as per my rarlier message.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
A couple of things it could be:
- You may have turned the brightness/contract all the way down accidently
- The Freeview channel might be slighly off and need fine-tuning
- Hardware fault - Backlight
- Hardware fault - Backlight inverter
In regards to options 1 and 2, you would probably be best to perform a "power reset" of the TV. Follow the instructions : HERE
In regards to 3 and 4, you would need to contact an authorised Sony Repair Centre : HERE in order to get this diagnosed.
At this moment in time, I cannot think of any further options. Therefore do a power reset and if that works, great. Remember if it does work, you will have lost all settings on the tv (ie freeview channels), simple go through the setup procedures again (ie retuning)
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok, thanks for the suggestions. Will try this ....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
TV working fine until today, no picture or standby light, no back light. very loud volume, unable to switch off TV, have to unplug.
