- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
when I connect USB mouse to the TV (KDL-42W805A) it works well in the internet browser. But when I connect USB keyboard it is not supported. Why? What can I do to get it worked?
br
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
As far as im aware, USB mice and USB keyboards are not supported. So if it does work, you've got luck on your side.
Now, if that mouse is bluetooth enabled, that might explain why it works. Because according to the imanual : Here
It states :
"Notes
- Only a Bluetooth mouse can be registered to the TV. And you can register up to 3 type mouses.
- Pointer operation of the Bluetooth mouse can be performed only on an internet browser. "
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
It states :
"Notes
Cheers
