Cannot use Auto timer record , the prog i want to record goes into the Error List, the details say that another prog is recording (there is not !)
I think the problem is related to this....when i go into Timer List it displays a prog thats on timer from last March with red dot by it , pressing the "record stop" does nothing and cannot scroll to another else on the page.
Have de-registered the USB stick and then re-registered but its still on the listing.
I can manually set the timer clock to record progs though ,and this method works, but want to just set the normal auto timer.This pic shows the display.
Solved! Go to Solution.
A simple reboot (power off button pressed for a long time) should have done the same result without the need to reset everything, good in any case that you solved the issue.
Problem solved, did a Factory Reset and it deleted the timed prog.
