Hi,
I would like to ask how I can find the working hours of a Sony KDL50W805B.
I tried (i+)+(5)+(Volume Up)+(Power) and Self Check (i+)+(5)+(Volume Down)+(Power). I see the menus, but I couldn't find working hours.
Is there anything else that I can do?
Thank you in advance.
Solved! Go to Solution.
Hi,
I mean usage hours of TV. But I found it
From Remote
Press (I+)
5
Volume Down
Power
Hi @stavrosthess and welcome to the Community
Can you explain what you mean by 'working hours'
and what are you trying to do?
Thanks
Hi again
Glad you managed to sort it
