battery problem
woodymorenito
battery problem
hi,
i have a vaio pcg-k315b he works fine on the ac adapter but when i disconnect the adapter the pc is dead. so now the pc doesn't recognize the battery. i called sony but they have no idea.
can you help me
1 ODPOWIEDŹ 1
Boboy
hi there,
if you haven't done yet, best thing to do is to register your unit in e-support, log every detail of your laptop's fault and they will reply to guide you with the troubleshooting.
e-support works and they are really a good help. best of all it's free.
cheers!
