Hi All,
I have sony VIVO VPCCB, is my system BOOTMNG file missing can you please help me
akhtar
Hi akhtar,
Try a Startup Repair. Tap F8 at boot to access this option.
Rich
hi rich,
I cant go startup repair section, please advise
akhtar
Hi akhtar,
If you are unable to access the repair option via F8 then there could be more problems than a missing file. Is the had disk recognised in the BIOS? Tap F2 to enter BIOS.
You could try creating a repair disk on another computer with the same OS. Here are a couple of links that will help.
http://windows.microsoft.com/is-IS/windows7/Create-a-system-repair-disc
You can also download a repair disk for a small charge.
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Rich
Hi Rich,
Thanks for your advise, Rich I have installed new windows 7 but original Vaio feature are not installed can i download any where else
Thanks
akhtar
Hi akhtar,
Drivers and utilities can be downloaded from the Sony Support site but most of the original pre-installed software (including WinDVD) is not available to download.
http://www.sony.co.uk/support/en
Rich
