Cant Download Vaio Care
SOLVED
gastyli
Explorer
I go to the correct page in support and select download but I get error message that ftp server has not responded.
tried different browsers but still the same. Any ideas where I can get this from please as it seems to have disappeared off my laptop ?
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
...and also the original utility from:
http://www.sony.co.uk/support/en/product/VPCEE2E1E_WI/downloads/VAIO_Care_6.0.0.15080_5105
Both work.
Rich
Go n-éirí an bóthar leat
8 REPLIES 8
rich912
Contributor
Hi gastyli,
This may be a temporary glitch on the server but without knowing your Vaio model we cannot check whether the download works at our end.
Rich
gastyli
Explorer
Thanks rich good point :smileyblush:
Sony Vaio VPCEE2E1E
In fact even using the Sony  Update option on my Vaio it returns a similar message
Message was edited by: gastyli
rich912
Contributor
Hi gastyli,
It downloads fine on my machine VAIO Care - 6.4.2.11150 (EP0000261503.exe) size 58.0MB.
I suggest that you try downloading with your security software temporarily disabled.
Rich
rich912
Contributor
Hi gastyli,
Downloaded from the Sony UK site...
http://www.sony.co.uk/support/en/product/VPCEE2E1E_WI/downloads/EP0000261503_6068
Rich
rich912
Contributor
Both work.
Rich
gastyli
Explorer
I can download from the US website...presumably for the wrong model but from the UK site for minr. What URL are you using rich ?
Mine is
ftp:vaio-link.com/pub/vaio/updates/EP0000261503.exe
gastyli
Explorer
yep...either of those URLs work...thanks again rich
rich912
Contributor
You’re welcome gastyli:smileyhappy:
