Im wondering whats the normal temp on a397xp.
WIth battery I get around 50...after 10 min- just surfing. With El-cord plugged 59-up to 64., then the fan starts and Ill stay on 60 ...this with only surfing on the net- no games playing.
I have used mobilmeter. Is this normal.
55-60 I'd say
Using click 2 dvd now. The temp Is at 67 c...
Hmmm, you can't compare the ULV with the normal PentiumM. The Pentium M ULV produced less than 10watts heat. The normal PM has more than the double of them.
Nothing dramatic there but for an Intel Pentium M Processor 760 I would suggest that you are on the upper limits of acceptability.
How old is the notebook – possibly the cooling vents require cleaning.
You could always try changing the CPU control to adaptive (for the battery profile).
The computer Is 1 week old. I had a question earlier with th fan going- stopping 5 sec then keep going.
Average I have 60 c... Is that to much richie or normal.
I get around 55 on adaptive mode- and thats not to bad.
67 Is the highest I had, but this is what mobilmeter say,
Been on for about 3 hours - and Im on 60 c right now.
That's about right. Idle temperature should be about 55C with peaks up to about 70C when the fan should run at higher speed.
Thx. I realy needed that answer Rob. Really fantastic that u guys can answer so fast. Thx alot everyone.
Also Im wondering Rob, the fan goes then stops for 5 sec- then starts and goes like this constantly Is this normal.
Yes, it's normal. Mine's doing it right now at 56C.
