Memory sticks
Stubsee
New
Memory sticks
Hello..I am trying to use a memory stick 4GB on my sony vaio and it's not showing in the my computer list when it's inserted..therefore I am unable to save data on it 😞 can anyone advise please! Much appreciated!! Claire.
5 REPLIES 5
Blencogo
Hi Claire and welcome.
Can you tell us the type of Memory Stick - it will be written on it.
Please also tell us which Sony Vaio model you have and what version of windows it is running.
Thanks
:thinking:
Stubsee
New
Hello,
Thank you so much for coming back to me :slight_smile:
My sony is VPCEE2E1E and the stick is a HP Flash Drive v125w
Please let me know if you need anything else...and this will be a life saver!! :slight_smile:
Claire.
Stubsee
New
This is probably a really ditsy comment yet how do I find out which version of windows I am running? :thinking:
Blencogo
Your Vaio was sold with Windows 7 installed and your HP memory stick should work OK.
Have you used it before?
Where are you looking for the drive to show up on your computer?  Try plugging it in, right-click on the START icon and choose 'Explore'.  Scroll down in the 'Folder' box to the bottom.  Does your HP Drive show above 'Network' and below 'Windows'?
:thinking:
Stubsee
New
No..it is not showing up at all and then I am not sure how to access it to save files on it 😞 I haven't used this one before yet I did have this issue before with a stick 😞
Thanks for your help...it's really appreciated :))
