NEED INTERVIDEO WINDVD8 SOFTWARE
profile.country.en_GB.title
saikamma
I've uninstalled intervideo windvd8 from my system and deleted the folder and also removed the registry keys permanently from my system in an attempt to make my Blu-ray drive work properly as it doesnt recognize any blu-ray dvd. Is there anyway I can get the original software so that I can update it back? Currently the drive doesnt play any BD disc. only DVD's mine is a VGN-FZ21M.
3 ODPOW. 3
Thalamus.
VIP
Hi KRISHNASAI,
the full version of Win DVD is not available to download, only updates can be found on the Sony Vaio-Link site..
Unfortunately the only way to re-install win DVD BD is to run the Vaio recovery utility and restore your Vaio back to factory settings.. :slight_frown:
Make sure you back up important data first.. :wink:
saikamma
Hi KRISHNASAI,
Can I install Windvd 9 now? and if so, will my drive be able to recognize Blu-ray discs ?I will buy a Windvd 9 if that could solve the problem.
Thalamus.
VIP
Hi KRISHNASAI,
WinDVD 9 Plus Blu-ray should work ok on your vaio, also you may want to consider PowerDVD ultra, but it's your choice whether or not to purchase and install..:smileywink:
