problem in insatlling drivers downloaded from viao site like video drivers
SOLVED
profile.country.en_GB.title
ashu4evr
Visitor
My model is vgn-fs115m, i am able to download drivers from sony vaio as per my model but with some of the drivers when i unzipping some drivers i am not geeting any setup file for that driver ex video driver  so please let me know how to install these drivers if i am not able to dowload setup file from the site.
please help me out?
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi ashu4evr,
You need to update the driver from within Device Manager using the ‘Have Disk’ method.
Extract the files from the installation package to a known location.
For Vista and Win 7:
Click Start > Control Panel.
Double click Device Manager.
Right click the device and select Properties
Click the Driver tab.
Click Update Driver.
Click Browse my computer for driver software.
Click Let me pick from a list...
Click Have Disk....
Click Browse and navigate to the folder where you placed the extracted files.
Click OK.
Click Next.
Click Finish.
Reboot your system if requested.
For XP:
  1. Extract the files from the installation package.
  2. Click Start >  Control Panel.
  3. Double-click the System icon. Note: Select Switch to classic view if the system icon is not visible.
  4. Click the Hardware tab.
  5. Click Device Manager.
  6. Click the + symbol in front Device Category to expand the section.
  7. Right-click the Device and click Properties.
  8. Click the Driver tab.
  9. Click Update Driver.
  10. Click No, not this time and click Next.
  11. Click Install from a list or specified location and click Next.
  12. Click Don't search. I will choose the driver to install and click Next.
  13. Click Have Disk....
  14. Click Browse and navigate to the folder where you placed the extracted files.
  15. Click OK.
  16. Click Next.
  17. Click Finish.
  18. Reboot your system if requested.
Rich
Message was edited by: rich912
Go n-éirí an bóthar leat
2 REPLIES 2
rich912
Contributor
Hi ashu4evr,
Click Have Disk....
Click OK.
Click Next.
Click Finish.
For XP:
  15. Click OK.
  16. Click Next.
  17. Click Finish.
Rich
cra_ashu
New
I have formated the VAIO-VGN-FS115M(model), by using bootable pendrive.
However Windows 7(32bit) have been installed but the problem is Screen is not full screen as there is No INVIDIA Graphics driver that support Windows 7.
Just help me to get the full screen, i have checked screen resolution there is no problem with that.
please provide me driver that support WIN7
regards
Ashutosh
