profile.country.en_GB.title
andywagg
Visitor
Sony Vaio PCG-71312M
Hi
Can anyone tell me what the actual Sony model number is for this laptop as it does not exist if this is entered as the model.
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi andywagg,
I think you will find that the model is VPCEB1EOE  or similar. Have a look on the bottom right hand side of the screen surround.
Rich
Go n-éirí an bóthar leat
5 REPLIES 5
rich912
Contributor
Hi andywagg,
Rich
Laptopped
Visitor
The answe you got does not work either.
Sony needs to get it's serial identification sorted so people aren't wasting time trying to find out what their laptops are actually know as and not whats printed on the tin!
decargar e instalar hardware
rich912
Contributor
Hi leti333player,
You’re going to give a bit more than that to go on if you need assistance – preferably in English unless you post in your country of origin.
Rich
please,I'd like recive drivers for windows 7. Tanks
