Sony Vaio - won't connect wirelessly !!
profile.country.en_GB.title
rach1623
Visitor
I actually think I'm going to scream.
My husband bought 2 Sony Vaios recently, one for his business use and one to put away for my son for Christmas.
My husbands laptop (the only one we've tried at the moment as I daren't set the other one up!!) will connect to his wireless network in his office (BT Home Hub)
I have just brought his laptop into the house and tried to connect to our wireless Netgear WG111T, it says its connected (sometimes) but then try and open a web page and there is no internet connection.
I am also periodically getting the yellow exclamation mark on the signal strength saying 'no internet'
I am not very techie at all. My son's XBOX connects to our wireless fine and I do have it security enabled with a password. I deleted the network from hubbies laptop and let it find it again - still same problem.
I really don't want to start messing with my router as others have connected to it fine (when I've given them the password!!)
I have tried to update the wireless driver but it says its up to date.
I really don't want to get the other laptop out the box.... whats the point of having a wireless laptop when you can only connect to one network EVER.
Any help on this would be appreciated.
1 REPLY 1
Blencogo
Are any of the other working PCs using Windows 7?
What is your Netgear Router model - you are quoting WG111T which is the bit you plug into the laptop, not the router.
I think you need to look for a firmware upgrade for your router from Netgear to be able to connect to a Windows 7 A/G/N wireless card.
:thinking:
