Please help!!! My Vaio sz3vwn is cutting out
profile.country.en_GB.title
patmccab2
Visitor
I have a Sony Vaio sz3vwn it has started cutting out intermittently sometimes after 20mins sometimes more than 2 hrs. Each time it switches back on straight away. Any help would be great Thanx
3 REPLIES 3
Blencogo
It could be quite a few things!
Are you doing the same thing when it happens?
Have you installed any new software?
Are you still running Windows XP?
Try downloading PC Wizard 2010 and check your CPU temperature when playing a game or a DVD - the symptoms may be caused by overheating.
http://download.cnet.com/PC-Wizard-2010/3000-2094_4-10793737.html
Intermittent faults can be difficult to remedy and could be due to a poor contact somewhere.
:thinking:
patmccab2
Visitor
Yes have xp service pack 3 installed.....have downloaded and ran PC wizard 2010... CPU temp 52-55 degrees
laptop cuts out what ever i'm doing not just one thing. Sometimes it runs for 2hrs but mostly cuts out 15- 30 mins occasionally only goes for a couple of mins....have tried it on mains with and without battery and just on battery...nothing seems to help...Thank you for help
Blencogo
It is not overheating then and XP is very driver stable these days.
The only other thing worth trying is to look in Start -> Control Paanel -> Administrtive Tools -> Event Viewer and look in each of the categories for errors.  If there are errors they may give an indication of the cause.
The next step is probably to have the motherboard tested for poor contacts.  Try ringing one of Sony's service partners who may have some ideas and can estimate the cost of an investigation.
http://support.vaio.sony.eu/computing/vaio/contacts/asc.aspx?l=en_GB&m=VGN-SZ3XWP_C
:thinking:
