Comparte tu experiencia!
I have a Bravia TV (KDL-40HX803) and have streamed Media from my PC running Windows 10 with no problem.
However, having just upgraded the PC to windows 11 it will not play media music.
It sees all the folders but when it gets to the .mp3 file it errors with 'No music files found'.
It does play video clips.
Can anyone suggest a resolution please?
And on the computer everything is reproduced, maybe you have a problem with drivevirs?
Try to check if through Chrome Browser you can send an .mp3 to TV via Chromecast.
I don’t have chromecast and Sony support have suggested a s/w update through usb. However, it doesn’t work as the tv seems to ignore the usb and I can’t see how I can force an update.
Found usb with tv s/w update had been formatted as NTFS. Reformatted as FAT and it worked with s/w updated on tv. However, no change to the problem.
