Hello!
I have Vaio Z11MRN notebook with Vista.
Currently i have VAIO Update 4.0 installed.
I was searching the web and found that there is VAIO Smart Network 3.0 already, and installed version is 2.0. But Updater is silent instead of suggesting me such an update. Also i've found that there is Updater 4.1, but still it doesn't suggest me to update itself.
Is it weird or these new versions are not applicable to my notebook?
up
You can always check in the support section if there's an update available for your VAIO.
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-Z11MRN_B
Okay, there i read that latest version of Smart Network is 2.0.1.11050, the same as mine.
But also there i read that latest Wireless Lan Driver (Atheros AR928X) is 7.6.1.122 and my installed version is 7.6.0.114. Still Updater doesn't update it. It's written there, that this driver is available via VAIO Update...
up.
