VAIO Content Sharing
profile.country.en_GB.title
Blackers16
I Want to switch off the VAIO content sharing
5 ODPOW. 5
rich912
Blackers16
Hi rich912
Thanks for the reply.
Ive already had a look at that and the items I have copied below, the file names do not exactly match the ones on mine (the other 3 files I need to alter, the names match up with ones I have, so that shouldnt be a problem) Not being very technical, I am not sure what these are now called.  Any ideas?
I think the link you attached was from 2008 and these files have now changed names. My computer is a VAIO VPCEB4L1E and ive only had it a month.
VAIO Entertainment Database Service
VAIO Entertainment File Import Service
Thanks again
rich912
Hi Blackers16,
I have no idea what the recent version of these services is called, but if you list all Vaio services I will take a guess, or maybe another member can help.
I suggest that you try disabling anything with a similar name and then see whether there are any negative effects on other Vaio programs – you can always revert to the original status as long as you make a note of whether the service is set as ‘Automatic’ or ‘Manual’.
Go n-éirí an bóthar leat
gopal-chowdhury
these are what I get - what should I do to disable content sharing -
vaio care performance service
vaio content folder watcher
vaio content importer
vaio content metadata intelligent analysing manager
vaio content metadata intelligent network service manager
vaio content metadata xml interface
vaio device searcher
vaio entertainment common service
vaio event service
takrzem
Did you try Control Panel and VAIO Media Server settings?
Alternatively, go to Administrative Tools -> Services and stop Windows Media Player Network Sharing Service (& put it in the manual mode so it won't start automatically later)
