annulla
Cerca invece
Intendevi dire:
Vaio Control Centre missing from SVE1513A4E running WIn 10 Home 64 bit version 1803
RISOLTO
DrMopp
Membro
This machine was upgraded to Win 10 64 Home many months ago, and up until very recently I had VCC installed as the battery meter was showing 70% charged (a setting in VCC to extend battery life).  Cannot be sure when the change occurred, (probably only during the last week) but battery meter now shows 100% charged and I have no Vaio software installed, no Vaio Care, No Vaio Control Centre, nothing. Any ideas anyone?
1 SOLUZIONE ACCETTATA
Soluzioni accettate
DrMopp
Membro
Just in case it helps anyone else, I have resolved the issue, i.e. restored VAIO Control Centre to full working order, by installing the Sony Shared Library, Sony Firmware Extension Parser and Vaio Control Centre software indicated as Win 8.1 (64-bit). on the Sony support website.  Be aware though that these downloads are specific to machine range.
Visualizza soluzione nel messaggio originale
9 RISPOSTE 9
Mick_D
Moderator
Hi @DrMopp
Are you sure the Vaio software is missing and not just hidden? It's possible this happened during the W10 update.
Maybe check in All Programs and see if it's there?
Mick
DrMopp
Membro
Thanks for reply but definitely all gone, not listed in Apps and Features or in All Programs. Also searched C drive for 'Vaio' and found nothing. Question now is are these utilities available from anywhere? Nothing on Sony Support site.
Just to be clear it  was not the W10 upgrade that was responsible as it had been upgraded a long time ago and all was good, however the latest WIndows 'April Update' to version 1803 is the most likely reason.
Anonymous
Non applicabile
Hi, have you asked tech support about this yet? You can contact them here
DrMopp
Membro
Thanks, I have already been in contact with support and awaiting full response. Initial reaction was that VAIO software may not be compatible with Win 10.
Anonymous
Non applicabile
Hopefully you'll hear back from them soon. Please share the outcome here in case other forum members may run into something similar in future.
DrMopp
Membro
Answer from Tech Support was that there are no VAIO tools (Care, Control Centre, Gate) qualified for Windows 10 for this machine, but that some functions in the latest version may work whilst others would not.  I intend to try (re)installing the version of Control Centre for Windows 8.1 and see what happens. (after full backup of course!) I will report back shortly.
DrMopp
Membro
OK tried that, just get the message 'A newly (?) version is already installed n your computer. Installation is stopped" fed back to tech support but don't hold out much hope of a solution.
DrMopp
Membro
Final Sony support response is that VAIO Control Centre is not supported in Windows 10 on this machine.
DrMopp
Membro
