Vaio Flip 13A - Metal Casing 'Live' when Charging...
SOLVED
HardDriver
Member
Hi,
Anyone got this?  When charging via the mains charger I have a 2.14vdc leakage on the metal casing - when touch it gives a slight buzzing/tingling sensation on the fingers.
Disconnect - all okay.
Weird.
1 ACCEPTED SOLUTION
Accepted Solutions
HardDriver
Member
Found problem to be - using a plug lead with no earth, use original lead - all okay.
2 REPLIES 2
Drewde
Administrator
Hi HardDriver,
We advise you keep your laptop unplugged and get in touch with our support team. You can find the contact details here: http://bit.ly/17JzGwv
Please let us know how you get on.
HardDriver
Member
