Vaio Media Integrated Server
rusugabrielioan
Hello.
i own 2 vaio desktops (PCV-V1/g and VGC-V3S). i reinstall the windows on both of them and now i have a problem. i cannot reinstall the tuner. i read something on the internet and it says something about Sony Media Integrated Server. I don't have any recovery disks.
Can any of you please tell me where can i download this sofware from or where can i buy it from.
Thank you all for your attention.
1 ODPOWIEDŹ 1
Thalamus.
VIP
Hi rusugabrielioan,
Unfortunately Vaio Media Integrated Server is not available for download.. :slight_frown:
Did you remove the recovery partition when you re-installed windows on your V3S.?
You can check by going to Start > Control panel > Performance and Maintenance > Administrative Tools > Computer Management..
A new window should open click on Disk Management and maximise the window .
You should see Recovery Partition, C and D partitions.
If the recovery partition is still present, pressing F10 repeatedly when starting you vaio would normally would start the recovery process, this would restore your Vaio back to it's original factory settings..
