Hi, I can't print/spool an ADOBE reader document over a wi-fi link from a VPCEB1E0E/WI with W7 OS. The VAIO will successfully print any office document over the wi-fi LAN. Another VAIO with W7 (VGN-NW26M) has no such issues on the same LAN. I get a print error message 'no pages have been selected' when I've alterantively select all, pages in the range & a single page. In Reader page set up I cannot see the printer but when I select print I am able to select the printer & it's settings. The printer is correctly installed & works with 3 other notebooks including this one with anything but Reader (9.3). HELP PLEASE my daughter needs to print educational matter only provided in .pdf format.
You may find a solution in this thread from the Adobe forums: -
http://forums.adobe.com/thread/392800
Many thanks Blencogo. After reading the threads, I went for the killer solution of replacing 9.3.4 with 8.1.2 - works a treat & calms my daughter down a treat. Again thanks for your help.
I'm very glad you have fixed it.
