VGC-RC202 driver question
SOLVED
profile.country.en_GB.title
rowan91
Visitor
I have asked Vaio for info on what drivers I need to slipstream to do a clean XP re-install - all they say is buy the disks - just useless boiler plate answers.  Not very helpful so I thought I'd ask the experts.
I want rid of the raid0 - bad idea in the first place. Disks cleaned reformatted.
I read the recent post by Robmar0se, and thought I'd start my own from a different angle.
I have downloaded the original Intel 945 drivers from the Vaio website ( http://www.sony.co.uk/support/en/product/VGC-RC202/downloads/Preinstalled_Drivers_2314 ) but not sure which drivers I need to slipstream using nlite?
Anyone had a previous experience of doing this?
By the way can confirm there is no floppy or floppy plug on the mobo, clever!
TIA
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi Robmar0se,
Rowan91 did reply but there seems to have been a glitch on the system as it has disappeared. I received an email notification but it seems to have been created by you although obviously from Rowan91. Below is a copy:
Re: VGC-RC202 driver question
created by robmar0se in All-in-one Desktops - View the full discussion
________________________________________
Hi thank you for your reply.....that was the thread I was referring to actually.
Anyway I have got over the problem - I took a punt using Nlite I slipstreamed the following into XP Pro SP3 and hey presto the system recognised the drives.- great little system as it just knows where to put the files within the CD:
C:\Downloads\vaio\Drivers\Audio\WDM\STHDA.INF,0
C:\Downloads\vaio\Drivers\AverMedia Hybrid TV Tuner Card\34AVStrm.inf,0
C:\Downloads\vaio\Drivers\Chipset\XP\865.inf,0
C:\Downloads\vaio\Drivers\Chipset\XP\SP\ich5id2.inf,0
C:\Downloads\vaio\Drivers\Ethernet\e1000325.inf,0
C:\Downloads\vaio\Drivers\Memory Card Reader-Writer\UMH-U7.INF,0
C:\Downloads\vaio\Drivers\Modem\SnyHDANk.inf,0
C:\Downloads\vaio\Drivers\RAID\iaahci.inf,iaAHCI_ICH7R
C:\Downloads\vaio\Drivers\RAID\iaahci.inf,iaStor_ICH7DH
C:\Downloads\vaio\Drivers\Video\NVSY.INF,0
I believe that the bold items are the important ones, but I thought might as well do them all to save loading drivers later.
After this, Device manager showed no errors - however it did ask for SP3 - something about the drivers being wrong.  I just reran SP3 and all seems well.
Rich
Go n-éirí an bóthar leat
5 REPLIES 5
rich912
Contributor
Hi rowan91,
See whether this thread is of help.
https://www.sony-europe.com/discussions/thread/171864?start=0&tstart=0
Rich
robmar0se
Visitor
Hi any success?
rich912
Contributor
Hi Robmar0se,
Rich
rowan91
Visitor
Thanks Rich - yes it was me earlier, not sure what happened, I was trying to edit it!
Just goes to show that the forum experts are FAR FAR more helpful than the idiots at Sony who just give you boiler-plate answers.
rich912
Contributor
Hi rowan91,
I don’t think it was anything you did as the email notification said it was created by robmar0se – maybe you both pressed the send button at the same time:smileyconfused:
Rich
