Where I download vaio musicbox? I formatted my laptop.
profile.country.tr_TR.title
frodox
Hi, Where I download vaio musicbox? I looked at vaio website, but i could not find something about vaio musicbox. I find only an update software. Can anybody help me please?
3 ODPOW. 3
Thalamus.
VIP
Hi frodox
welcome to Club VAIO.. :slight_smile:
unfortunately, like other sony supplied pre-installed applications, musicbox is not available to download.. :slight_frown:
If you want the applications back on your Vaio then you'll have to run the Vaio recovery from the hidden recovery partition.
To do this Start your Vaio and when you see the Vaio logo screen press F10 repeatedly this normally would start the recovery process..
frodox
Thank you Thalamus...
I will try your suggestion... :wink:
Thalamus.
VIP
You're welcome, recovering your Vaio back to factory settings should restore all of the pre-installed applications.. :slight_smile:
