I don't know why it is not starting up it may be because before i went on one of
those movie websites. But everytime I switch on my computer, it does not go on
my desktop homepage instead it comes up with something called startup restore.
So i wait for it restore but at the end it just says startup repair cannot
repair this computer automatically. So i just press don't send and i go on
advanced options for system recovery and I have tried going on all of them but
none of them have worked. It comes up with things like system recovery and
system image recovery image but I don't even know what these things are. I just
got the computer one month ago so can someone please tell me what I have to do
next to get my computer working again. I don't even care if your method makes me
delete all my data as I have nothing impportant. Please can someone tell me a
step by step method as im not good with computer language. Some people have told me to go on safe mode but even that doesn't work. Btw I have a Sony vaio series E laptop. Thanks in advance
Hi lorobolorolo,
Follow this link for details on how to recover to factory settings. Type ‘Recovery’ in the search field and then click on ‘How to Recover you Vaio...’ If there is anything you are not sure of then please ask.
http://www.sony.co.uk/support/en/product/VPCEL1E1E_B/tips-and-solutions
Rich
Message was edited by: rich912
Hi lorobolorolo,
Rich
mine has been doing this on the 2 computers i own one of which is not sony do you not think windows is playing up
i have only had computer for 3 weeks and only started 2 weeks ago after update for windows
Hi Oliver0123,
Try restoring your Vaio back to a date before the problem occurred using either Vaio Care or Windows Restore.
If that doesn’t work then consider a restore to factory settings – backup any personal data you require first.
Rich
here is a link for full info https://www.sony.co.uk/discussions/message/822112 as already tried above
