HT-XT1
Giannis1981
Explorer
HT-XT1
Hello, can I connect my HT-XT1 soundbase with my iMac via cable or only via bluetooth ?
4 REPLIES 4
profile.country.RO.title
cosmingpx8
Member
Use nfc,or blututh ist anader version.
Giannis1981
Explorer
Thank you.
NFC is not for iMac. I'd like to use cable for more stable connection.
Pavvy8
Member
iMacs are very very very picky with their connections so i highly doubt you will find any cables to connect the soundbase to XT1. you are stuck with Bluetooth
you can upgrade to HTXT3 that features the new technology called LDAC that will not compress the sounds when transferring via bluetooth
Giannis1981
Explorer
I am using 3.5mm Moshi cable and it's sounds good. Bluetooth is very good also btw. Thank you.
