- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
June 2015
June 2015
HT-XT1
Hello, can I connect my HT-XT1 soundbase with my iMac via cable or only via bluetooth ?
4 REPLIES 4
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2015
June 2015
Use nfc,or blututh ist anader version.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2015
June 2015
Thank you.
NFC is not for iMac. I'd like to use cable for more stable connection.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August 2015
August 2015
iMacs are very very very picky with their connections so i highly doubt you will find any cables to connect the soundbase to XT1. you are stuck with Bluetooth
you can upgrade to HTXT3 that features the new technology called LDAC that will not compress the sounds when transferring via bluetooth
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August 2015
August 2015
I am using 3.5mm Moshi cable and it's sounds good. Bluetooth is very good also btw. Thank you.
