Hi all,
Recently i have installed this system into my car, but i can't connect my HTC one to it.
I can see that it is not on the compatibility list.
My problem is, that bluetooth won't pair. When i press and hold the BT button for 5 seconds, the logo just lit, and is not flashing.
I've also tried to delete all registered bluetooth devices, but that did not work.
do you know how to make it flash/blink again so i can atleast find this bluetooth device on my phone?
Thanks in advance,
Guus
Hi there
My advice it to turn Bluetooth off from the MEX unit by pressing and holding the [BT] button. Then you can delete any registered devices. Then hold the [BT] button again to enter pairing mode.
Another thing you could try is disconnecting the cars battery for a couple of minutes, then reconnecting it again. This may reset the MEX unit.
Your HTC must be compatible with the following bluetooth profiles in order for it to work:
Cheers
