nwz-f886
nwz-f886
Does Sony know about an issue with this player , light is bleding from the corners?
1 REPLY 1
Nobody-in-particular
Contributor
Hi this is a user forum so I cannot say what Sony is aware of but it would seem you are not alone in reporting this issue though.
If you contact Sony support direct they may be able to assit you, but as this is a harware problem there is not much that the community can do to help.
