Hi,
When I had a VAIO it came with Sonicstage & I backed up my CD library using Sonicstage. I then gave my CD's away.
My laptop screen died so the laptop was no longer useable & I got a new acer laptop.
I am not unable to buy Sonicstage so have all my albums saved as ARTAC files but cannot seem to find any software to convert them to Mp3, can you help?
Justin
Hi justinswain, if you search around using Google or similar I am sure you will be able to find an ARTAC file conversion program, once you find one do some research to ensure that other users have not had any problems with viruses or similar nasties before downloading.
