- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
January 2013
January 2013
usb not supported problem
Hi my DAB700U is saying my ipod shuffle 1st gen is not supported in usb anyway of fixing this
Thanks
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2013
January 2013
Hi and welcome to the forum.
Looking at the compatibility for iPod products, quite a few are supported by sorry to say the shuffle are not listed.
http://www.sony.co.uk/support/en/product/CDX-DAB700U/compatibility
Rather that buying a whole new iPod, you could just use a USB flash drive and load your songs on to that instead as this product does support m4a files which is what iTunes usually uses.
I hope that helps.
