Condividi la tua esperienza!
will the NWZ-E585 work with the USB connector & Ford SYNC in my Fiesta?
I am extremely surprised how difficult it is proving to discover which devices will work with the audio system on my Ford Fiesta. The Sony documentation does not help, nor does the Ford dealer really have a clue.
some of the info about the Walkamn in general seem to imply that the USB connection will ONLY work for the transfer of files. Which seems very primitive.
John
York, UK
Hi,
If you connect your walkman to a PC it acts like a standard hdd. In general car audio devices from various manufacturers are supporting this. Don't know what Ford Sync is doing exactly but I would asume the everything should work fine.
Cheers
PD
