I am using a Sony BRAVIA KD49XE8396 in the UK.
When I go to Home, and then use the voice search, the results returned are for the US not the UK.
For example, if you search for 'Doctor Strange' it shows it is available on Netflix and Google play.
If you follow the link to Netflix it says its not available in your region. Same for Google play, its only available to buy not rent.
How do I change the search to use the UK services (the ones I am logged into and using on this TV) and not the US versions.
