Wer hat bei diesem Thema „Ich auch“ angegeben
genbusu
Neues Mitglied
How do I perform a factory reset on Sony's Android TV if I don't know the PIN-code
https://www.sony.co.uk/electronics/support/articles/00122829
NOTES:
  • The factory reset may take a few moments. Please wait until your're informed that the process has been completed
  • If you had set a PIN-code on your TV, you will be asked to enter this PIN-code when you select the option "Erase everything"
When I am roessing "Erase everything"  is asking for  a PIN-code but I never set a PIN code, maybe my kids, but they don't remember.
How do I perform a factory reset on Sony's Android TV if I donlt know the PIN-code that I need to fill ?
Kind Regards
Eugen
