- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
March 2019
March 2019
@IanTomBower wrote:I have inadvertently protected a recording from Freeview on my HDD connected to the REC USB of my Sony XE90 65" TV..
When trying to delete the recording I get the message 'To delete, release the protection first' but I cannot find a way to do this.
Any help would be appreciated.
Thank you.
Hi @IanTomBower
I don't use YouView (it is disabled) so it may be different for you. [On Your Remote]
1. Display the Recorded Title List. In my case [Guide] move left and select Recorded Title List.
2. Highlight the protected recordings and then press [Action Menu]
3. Move down to Protect and select it.
4. Tick or Untick the recordings you want to Protect or Unprotect.
5. Make sure you select Set to save your changes.
