Hello,
It sounds like you need to change the audio output setting on the television.
Please try the following:
- When using an external audio system, audio out of the TV can be controlled using the TV’s remote.
- To output the sound from the connected audio system, press HOME, then select [Settings] → [Sound] → [Headphone/Audio Out] → [Audio Out].
Kind regards
